I got a little problem.
I have setup my headphones and stuff. But i hear the sound in my headphones and my speakers @ the same time..how do i fix that?
geposted Thu 12 Aug 10 @ 6:53 pm
same problem ... then i found the function "headphone_mix 0%"
go to --> config --> mapper and assign this function with a control key eg CTRL-H (or whatever you like) ...
instead of 0% you can choose any number between 0 and 100 depending on
how much of the master-output you want to hear.
geposted Sat 28 Aug 10 @ 10:20 am
good morning I have the asio driver i am using with the denon 2500. I installed vdj and it says asio has an error. Any advice on fixing this I have uninstalled both programs with no change.
geposted Sat 28 Aug 10 @ 10:32 am
Hello, i have an important question i need to ask
i currently have the following:
1)cdj 1000 mk3
2)djm600
3)audio 4 soundcard
4)virtual dj
question is, would I be able to connect the mixer to the laptop and use virtual dj to load tracks to the cdj's instead of using a regular cd??
thanking you in advance
1)cdj 1000 mk3
2)djm600
3)audio 4 soundcard
4)virtual dj
geposted Sat 28 Aug 10 @ 10:21 pm
yes you can.
download timecode to connect the cdjs and the mixer by cable https://virtualdj.com/products/timecode/cd.html
geposted Sun 29 Aug 10 @ 7:05 am
