Forum: VirtualDJ Plugins
Topic: Reverb by TexZK - Page: 1
NEW AUDIO-EFFECT
Released the new Reverb v1.0 created by TexZK.
>>> http://www.virtualdj.com/addons/11861/Reverb.html
Description:
Reverberation effect.
Features:
_ Dual Dry/Wet behavior: 0-50% controls the reverberation amount, 50-100% controls the freezing amount
_ Room size, from small room to very large hall - NOTE: there's no "timeshift" effect
_ Reverberation (feedback) high-pass filter
_ Reverberation (feedback) low-pass filter
bye,
Gabriele DiJ
geposted Fri 13 Aug 10 @ 2:35 pm
Oh man your on a roll, keep em comin!!! Great job.
Thank you
Huey
TexZK is the first one to use the new engine to generate sound when you stop playing
(for your information, the engine was there since vdj 4.1 but noone had the time to develop such a plugin)
So try it now : play then press pause and enjoy ;-)
Great Job!! Knew you had it!! Allright! this made my weekend!! ha,ha
@TexZK
I think you should write in Plugin.cpp
#define	DEFAULT_ROOM_SIZE		0.5
instead of
#define	DEFAULT_ROOM_SIZE		0.9
This is a badass plugin! Would it be possible for you to make the loopout plugin work the same way? When you stop the track it still plays out?
Thanks for your time
Huey
@ djcel:
Fixed in v1.0b
@ beatbreaker1:
It could have been developed since VDJ v4.1, but no one made that. I think it should be funnier to make something like the Beatmasher of Traktor. But, as for now, I'm getting back to work on my junior degree thesis project... :-(
Thats what i thought "Beat" i told you this a while back.. @Tex7K thanks again!
@Tracker, hmmm, don't remember that..............
@TexZK, good luck and thanks!!
Huey
hello
I want commended for his work texzk reverb addons that I find great because it works as real as soon as you put the plate on the effect continues to break worked, which is very helpful for mixing hard ...
a big thank you for your work
we talk on the ->French forum<-->démo audio<-
a + and a good mix all
p.s: sorry for the translation:)
Thanks mates ;-)
There's no problem for the translation! Anyway, I can still understand basic French, since I studied it (many) years ago, and sounds close to my Italian dialect sometimes :D
Can you make a mac version for Mac user like me please? Make the Mac version too please!
I did not read the translation. Now that I have read It. I now understand that DJ Cel is working on porting it to Mac too.
I am very excited. I can not wait!
I just tried this plugin and the sound starts playing slow as soon as the effect is on.
I'm using an EeePC right now so maybe it's because the computer is too slow.
The DSP uses double precision samples, maybe that's why it slows down. There's also another strange bug to be fixed. If sound quality isn't affected much, I'll switch to single precision floating point values.
I think you should make 2 then, 1 for weaker systems and 1 for systems with a little more power.
Just my 2 cents
Huey
I have just converted "Reverb" for Mac OS
Feel free to download it
PS: @TexZK
I have uploaded the new source code too for both PC & Mac
Thank you Djcel for porting it to mac. Thank you DJ TexZK for creating It.
Will this also work for the VDJ Rmx Console Edition?
Sorry, the RMX DJ Console Edition is a limited version of the software and does not support custom effects.
You can upgrade to the full VirtualDJ Professional at a considerable discount by going to http://www.virtualdj.com/buy/index.html
67%
