I have built a 1024x768 skin, based on Apopsis' TimeCode Power skin, but with Video in mind. The skin supports VDJ 3.0, containing Full Video Preview Panels or a Panel with just the Video and Audio Crossfaders. I have moved the Text and Video Transistion buttons out to the main layer of the skin.
I have supplied 3 colors, the Blue from the TimeCode Power skin, a Pea Green and a Plum. I know you maybe saying WTF, but take a look! They are very soothing to the eye, plus they are different.
As the title says it is a Power Users skin. Those of you that have the TCVs, TCCDs, DACs, DMCs, XP10s, etc. may find this skin very useful if you want to do video.
You comments are appreciated, and hopefully the skin will be available in the Downloads shortly. I just uploaded it, before this post.
cstoll
cstoll
geposted Fri 10 Jun 05 @ 7:00 am
Great work CS!
geposted Fri 10 Jun 05 @ 7:13 am
Thanks cstoll.
geposted Fri 10 Jun 05 @ 9:25 am
cstoll,
I really like your skin. Good job with this one. Simple and leaves lots of room for what we need with tcv.
Killabee44
Killabee44
geposted Sat 11 Jun 05 @ 7:23 pm
be looking out for more team effort skins, CS has got xml skills :)
geposted Sat 11 Jun 05 @ 9:39 pm
Thanks for all the props. As, Cyderhouse said; there is another in the works.
cstoll
cstoll
geposted Sun 12 Jun 05 @ 7:09 am
good work cstoll
geposted Sun 12 Jun 05 @ 4:37 pm
Thanks to cstoll and all of you who have the ability to create and understand c++.
This baby is right up my alley, love the viewing area of the browser/recordcase and waitlist.
A couple of things for developing:
Is there a pitch reset button somewhere?
I right click on the clock and it resets immediately instead of gradually.
Can we have a larger 12 hr clock?
Can you make the cue markers/bar a bit larger larger?
Is there a way to put the vu's beside each other and a little wider?
Never realized how much I struggled with the wave form colors in the Pioneer 700.
The orange/green sort of grew on me from using the default 3.0 skin, much easier to see.
Thank you all.
Thank you all.
geposted Sun 12 Jun 05 @ 10:32 pm
From mp3rick-- A couple of things for developing:
-- Yes, right click on the pitch percentage read-out.
-- What are you asking for? I am unsure of what you mean?
-- Where would you like it?
-- Not by much in the current confiuration. But will try.
-- Th reasoning for the edge is to have the entire space across the top for the wave graph.
-- I think you will like the next skin I am going to be building as they will be side-by-side.
Thanks for the comments.
cstoll
cstoll
geposted Sun 12 Jun 05 @ 11:58 pm
After using it all day today, I wouldn't change a thing.
It is so clean and uncluttered, much easier on the eyes.
The RC visibility is 100% better, I can see twice the amount of tracks now.
With MT activated you hardly notice the immediate reset, I never go more than 10 anyway.
However, I found that if you left click on the % it will take you to -33% RIGHT NOW!
Note to self, never left click on %.....
geposted Mon 13 Jun 05 @ 2:39 am
Thanks for the feedback. And I will post a fix to the -left click- issue.
cstoll
cstoll
geposted Mon 13 Jun 05 @ 3:35 am
Ok, just sent up an update to Automix fixing the Pitch issue.
Left click on the Pitch % will adjust the pitch to set bpm to same of the opposite deck.
DblClick and RightClick will reset pitch to 0%
Hope this helps in not getting those massive drops of -33% for Rick.
Anyhow, this seems to be actually a bug or just undocumented function, because it seems that if you create a button for pitch and you don't code for a Left, Dbl or Right click then the reaction to one of the choices is to set Value to Zero (0), which in my opinion is not good.
The reaction should be 'nothing', don't change. Anyhow, spilling my beans here and I should be posting it in the bug forum.
Glad you all are enjoying the skin.
cstoll
cstoll
geposted Mon 13 Jun 05 @ 4:16 am
Hey Rick, you said about the orange colour...
It took me many.. hours of "try and error" (and zip and reload the skin) until i achieve this orange colour for the timers... (V-mix skin is based on "apopsis-TC power" skin)
It was one of the most tricky parts.. Here is the orange color in xml: color="#F78E0F"
How many possibilities one has in a 6-digit (hexadecimal) number to find the right value....?
Btw., Cstoll if you (or anyone else) has a kind of a "map" for colours in the xml,
i'd like to see it.
i'd like to see it.
geposted Mon 13 Jun 05 @ 8:25 am
=> #RGB
with R,G and B from 00 to FF (in hexadecimal) [so from 0 to 255 (in decimal)]
try that:
http://www.laltruiste.com/document.php?url=http://www.laltruiste.com/courshtml/couleur.html#bas
try that:
geposted Mon 13 Jun 05 @ 12:08 pm
apopsis,
I hope you didn't misunderstand me, I like the colors in the waveform MORE than what I was used to in the 700 skin.
cstoll,
Thanks for addressing that so quickly.
Again, this is a great skin, thanks for the effort.
Rick
cstoll,
Rick
geposted Mon 13 Jun 05 @ 1:06 pm
@apopsis -
Not familiar with the site djcel put up, but here is another site you can look at. It's a shorter list of colors, but you get the concept.
http://www.w3schools.com/html/html_colors.asp
Here is a color scheme tool available for free online. Allows you to set values in RGB or HEX.
http://www.colorschemer.com/online.html
cstoll
cstoll
geposted Mon 13 Jun 05 @ 6:00 pm
Can we get an autoplay option say on a right click menu?
I dont want it on the main interface either, trust me.
Hate the sight of it, but it is necessary for dinner and when I want to load up some at home and just listen.
Changing the skin to do that, is what I had to do.
Is there a way?
Or is it here and I am missing it?
R
Is there a way?
R
geposted Thu 16 Jun 05 @ 12:34 am
Rick,
Maybe putting in a panel that you can open up whenever you need it? What do you think?
geposted Thu 16 Jun 05 @ 7:23 am
Hey, i'll take it anyway I can get it....
geposted Thu 16 Jun 05 @ 11:46 am
Why not hit the 'star' in the Playlist panel??
I have never understood the 'AutoMix' button on the Default skin, I mean - not only does it Mix two tunes but it Beat Locks them, with the STAR (Playlist AutoMix) at least it just mixes the tracks at the BMP they are, which for easy listening (dinner music) is perfect.
cstoll
cstoll
geposted Thu 16 Jun 05 @ 1:04 pm
