Hi there, i have 2 technnics 1200's connected to a numark dm950 usb mixer, the mixer connected to the pc.
I sed to be able to use virtual dj to recorda set from the decks, since the update to pro, that option is no longer there, is there any way of downloading an older version.
I also have the touch dvs system..will this work with virtual dj?
Hope you can help.
Hope you can help.
geposted Sat 14 Aug 10 @ 4:50 pm
Most mixers usually have a booth monitor out, you could run the booth line from the mixer into your computers microphone input, then when recording select "line in" instead of "master" in VDJ, you need to note if using this method, if you use a microphone through your mixer, this usually won't run through the booth output to prevent feedback, but if you wanted to introduce your set you could pre record your vocals and play them through the sampler or better yet, one of the decks and scratch it for an interesting effect. I use a djm 600 (non midi) and this works for me to record mixes.
geposted Sun 15 Aug 10 @ 9:13 am
You can also use the record output, if the mixer has one.
Please see https://virtualdj.com/homepage/jpboggis/blogs/4135/Recording_your_set_or_broadcasting_when_using_an_external_DJ_mixer.html
geposted Sun 15 Aug 10 @ 11:08 am
