Hello all I'm back after Geeking out at a Gig using VDJ 3.0.
Yes i think there is Hope here. This is what you need to
install. FFDSHOW is a DirectShow decoding filter for decompressing
DivX, XviD, WMV, MPEG-1 and MPEG-2 movies. Now you need to
read carefully how to use it. It's easy but very advanced & yes
I use this all the time now with VDJ 3.0. No Stutts or Jerks;
just smooth videos. This program intercepts the DirectShow calls for the Codecs; That's why this still works with VDJ 3.0. First you Download from here:
http://www.free-codecs.com/FFDShow_download.htm
Download the newest one on that site.
Then you Unzip this to wherever you want. Than Click on the
installer [ffdshow-20050609.exe]; This is located wherever
you un-zipped it. Now Juring the install you'll see Checkmarks
on the Types of video Types. You can leave Defaults but Check
where it says [Mpeg1] & [Mpeg2] video Types as well. These are
un-checked by Default. Click next OK or whatever. Leave the next
screen [audio filters] Default. Click next, next.etc. If you experience
any problems just uninstall the problematic Codec in your computer. NOTE: Don't Click 1 or 2 on Preview window;
Keep on 1+2. Check This my MP1's Play using Less than
5% CPU utilization on Athlon XP 2400. Yah!
Please read the info file that comes with this. Hope this helps Ya'll...
geposted Fri 10 Jun 05 @ 12:47 pm
I will try it thanks for the info and clear explanation
Ewout
Ewout
geposted Fri 10 Jun 05 @ 6:26 pm
I have tested briefly and do not discover any improvements.
geposted Fri 10 Jun 05 @ 8:40 pm
O.K. so far so good. I've noticed that some of the Mpeg1 videos don't play so hot [they were free so could've been crappy encodes; but the VOB rips play awesome [less cpu]. Just rename
the .vob to .mpg; also ther's lots of PostProcessing features included
to enhance the videos. Kinda kool. The audio part doesn't get used
because VDJ 3.0 takes over after the video decoding > [VDJFilter] +
has 2 input pins; 1 audio in & 1 video [decoded video]; the
[video multiplexer/splitter audio part] runs straight to >VDJFilter audio pin. So enjoy the VDJ internal audio filters cause you stuck with it. Oh just try the OSD
setting; this displays stats on your video window. Have fun DJing & don't
activate the Mpeg1 on video codec settings page; this doesn't work very
well yet. Improvements are noticed most of the supported
codecs. mpeg2 [dvd], avi, 3ivx, divx, etc. Not Mpeg1. The
quality [video appearance seems better] as well. The Mpeg2
Ex: 30-40% less cpu. utilized. Remember to select Mpeg2
on the codec property page on ffdshow decoder page.
geposted Fri 10 Jun 05 @ 9:06 pm
After more testing I definately notice a reduce in cpu usage. Good work ;)
geposted Fri 10 Jun 05 @ 9:47 pm
Thumbs down here
I upgraded to the 72.13 nv drivers on my 6600gt and got a little bit of a performance gain (not much less than 5 points in aquamark) But the video seems to be a little better.
Using ffdshow totally freeks out vdj and videos aren't de-interlaced right and look very very bad. I uninstalled ffd and the de-interlacing problem is gone. Very strange.
geposted Sat 11 Jun 05 @ 6:17 am
Hello all, very strange Cyderhouse! that you have bad looking videos.
Maybe my settings are making my Set-Up better. Try the De-Interlace
Setting in the [Deinterlace] Settings page in FFDShow. Because ffdshow
leaves the videos naturally as the original. Forgot to mention that. Normal
decoders sometimes De-Interlace or the Video Card Does without you knowing
it [Progressive]. Well also depends on the Type of Videos Cyderhouse; Promo Only are naturally Interlace content on the DVD; also on my LCD i see it interlaced also so use the settings in FFDShow; just select [libavcodec], Don't use the audio Codec Page in FFDShow; keep all disabled; i find sometimes can fool VDJ & leaves video window Blank. Also Don't forget to enable your video type in FFDShow on the Codecs Page in FFDShow. I used this Last night Thursday & worked Flawlessly all night; not a single crash 4.5 hours
of videos. I Like this program alot! Some people even recognised the Program
& said they tried & liked this VDJ 3.0 as well. So if anyone has any questions just
post in Forum & I'll try my best to help you. Thanks all...
geposted Sat 11 Jun 05 @ 5:12 pm
Better Performance [dj homeboy]; excellent. I know that there's a
learning curve but well worth the effort right. You'll know when
FFDShow is Decoding the videos when you see a black [FF] icon bottom
right of screen. If you don't see this than FFDShow is not running; meaning
why you have no performance Gains. Check also on the Codecs Settings Page
in FFDShow for the Codec Type your using; should have [libavcodec] chosen.
This is the Library that takes over from your System Codecs. I hope i've
helped someway.
helped someway.
geposted Sat 11 Jun 05 @ 5:24 pm
Hey Cyber_2005, hit me on MSN IM or eMail from my profile. I have a question 4 U about this topic.
geposted Mon 13 Jun 05 @ 6:39 am
