Help,
I just got and used at my first event VDJ Pro 6...
Here is what I notice and asking what I need to set to fix this problem...
>>> Gain changes on most sounds I load...
>>> Gain changes when I double click to bring it back to mid...
First problem isn't as bad as the second where the sound gets really bad.
To fix it I needed to keep click on the button for it to final change back to sounding right.
If you need details of my system to answer this question please ask and I will provide.
Thanks and I hope you can help me out...
geposted Tue 17 Aug 10 @ 1:33 pm
I'm not really understanding whats happening to you?
"Gain changes on most sounds I load" ???
your going to have to clarify that? the songs change in volume as your playing them?? or the volume is wrong upon loading??
"Gain changes when I double click to bring it back to mid"
what exactly are you double clicking??
geposted Tue 17 Aug 10 @ 5:53 pm
Let me see if I can explain it a little better:
When I load a song the Gain button changes. Why is that happening...???
Next, I try to bring it back to normal or mid point by double clicking and
the button returns to mid point but the sound quality goes to H3LL...
I continue to click until the quality comes back to normal...
Why is this happening...???
Gain changes and when I try to bring back to midpoint the Sound Quality changes...
Sounds gets Distorted
geposted Tue 17 Aug 10 @ 6:11 pm
Did a little reading and found that I can disable this feature...
Let me see if this fix my problem...
If Gain button doesn't move I will not need to double click to bring it back to 0...
Which means I will not have those two problems
And I will get the RESPECT...
I will let you know if it doesn't work.
Thanks
Thanks
geposted Tue 17 Aug 10 @ 7:10 pm
The first time a song is loaded, VirtualDJ will calculate correct gain for it, along with other information such as BPM, key, etc.
Please see https://virtualdj.com/homepage/jpboggis/blogs/3972/Pre-analysing_your_music_collection.html
geposted Tue 17 Aug 10 @ 7:21 pm
The gain may also change whilst the track is playing if you attempt to play it before it has been analysed for the first time.
geposted Wed 18 Aug 10 @ 4:58 pm
Thanks guys...
I will start doing this tonight...
geposted Fri 20 Aug 10 @ 10:26 am
