This may be a stupid question but how do you load and use the visual plugins (i'm a new user). Where is this video window? I have vdj 3.
many thanks for your help
geposted Fri 10 Jun 05 @ 10:13 pm
First you need to have video plugins (the're extension is .svp) in the folder VideoEffects that is in the Virtualdj folder.
Then you must go to the Virtualdj settings, and go to the video tab. Check the plugins option and choose the plugin you want to use.
Then go to VDJ, play an mp3 and go to the video pannel that is in the default skin, near the eq, remix and cues.
geposted Sat 11 Jun 05 @ 4:46 pm
Thank you - I've got it now. Are there any more skins that show the visual plugins?
Thanks once again.
Thanks once again.
geposted Sat 11 Jun 05 @ 5:22 pm
Look in the skins download area. Only the last ones can do that.
geposted Sat 11 Jun 05 @ 9:57 pm
I NEED A PLUGIN OF MP3 RECORDER MUSIC + VIDEO PLAYER TOO. WHERE CAN I GET THEM? PLEASE HELP ME IF YOU CAN TELL ME.....
geposted Wed 06 Jul 05 @ 10:59 pm
First... STOP SHOUTING PLEASE!
Next: the mp3 encoder plugin (lame_enc.dll) is not provided by AtomixProduction but it is freeware. You can find it on the web.
Finally: If you're talking about video plugin (animations) like winamp video plugin, you will find the answer if you try a search on the forum... (sonique)
If you are talking about transition effects, it is not possible to change them by now.
Good Mix!
Good Mix!
geposted Thu 07 Jul 05 @ 9:04 am
