I seem to have a problem whenever my player needs to buffer the stream. It will say buffereing but never does and just sits there .. I always have to re-connect to the stream. Any ideas why? Ive tried it with winamp and Media player and they both do the same.
geposted Sat 11 Jun 05 @ 5:05 am
you may need to turn your stream rate down in config
geposted Sun 12 Jun 05 @ 10:33 am
HOW DO YOU SET UP A BROADCAST!?!?!?!?!?!?!
geposted Wed 15 Jun 05 @ 4:36 am
Ive turned it down but thats not the issue im talking about ... If it looses the stream for a second it should re-buffer and then continue playing. It will never re-continue .. you have to re-connect again. Like i can have it play for 15 minutes but if it drops out for a second to re-buffer .. It wont play again untill you re-connect which you can do like 5 seconds after it drops out ... Then it will play for another 10-15 minutes again.
geposted Wed 15 Jun 05 @ 5:40 am
