Forum: Wishes and new features
Topic: ClipBank Idea
Hi Scott
Any word on the folder Video Clip Randomizing plugin..?
I have an idea for you; can you make your existing ClipBank "ClipBoxes" assignable to a folder instead of a file therefore making the radomizer use all the video clip within that folder.
This would also give the ability to the "ClipBoxes" within the ClipBank a "Genre" option to better organize the type of clips to the type of music you are performing with, keeping things in sync and better organized from one location...is this possible..?
Thanks Scott
Joey....
geposted Tue 24 Aug 10 @ 8:07 am
I've not had time to work on it I'm afraid; far too many other things going on at present.
I'm unable to modify the clipbank plugin as I didn't create it and don't have the code for it. Any modifications to clipbank are for the dev team to do.
Alright Scott, I now see it was Sclavel...and I know he has his hands full now..
Did you get my "Test" results I pm you..?
Thanks
Joey...
