Forum: Old versions
Topic: How to connect an Imix to the virtual dj
hey,
love the virtual dj, but how do i connect the imix to it? i plugged in the USB and nothing happens.... im assuming you have to reset something in the virtual dj programme to allow it to see the imix?
any help would be wonderful as im eager to try out the imix!!!!
thanks,
Jem.
geposted Fri 27 Aug 10 @ 10:58 am
Sorry, VirtualDJ Home Edition does not support any external MIDI controllers - https://virtualdj.com/products/homeedition.html :
Quote :
Designed for bedroom DJs or DJs who want to discover the art of DJing at a low cost. VirtualDJ HomeEdition includes all the features of the professional VirtualDJ software except for direct 2nd Video Output (Window Mode only) and those which involve additional hardware (mixer, turntable, MIDI, ...).
So if you intend to mix using your mouse to move the crossfader, then VDJ HomeEdition might be what you're looking for.
You will need to upgrade to VirtualDJ Professional: https://virtualdj.com/buy/
You can download the trial of VirtualDJ Pro from https://virtualdj.com/download/trial.html
cooool i see thanks for your help :)
