what would cause a signal that is 100% start to get a loss after playing for a period of 20-30min.?
geposted Sun 12 Jun 05 @ 10:55 pm
very likely because of the cracked version.. sorry
its a bug in that version
buy the full legal version to have it fully working with timecode :)
geposted Mon 13 Jun 05 @ 3:48 am
i am using the demo so mayne the demo is buggy?
geposted Mon 13 Jun 05 @ 5:55 am
oh... I see.. you dropped the cracked version .. Good! :)
The demo version should work well with ONE timecode deck.
(2 decks are disabled)
why signal is dropping, I'm not sure of..
Maybe one of the many good timecode users here have a clue...
anyone?
anyone?
geposted Mon 13 Jun 05 @ 10:54 am
my guess is it might be a soundcard issue(i have a soundblaster live), or maybe my RAM i only have 256.
geposted Mon 13 Jun 05 @ 2:48 pm
I have similar problem with my laptop. Every 3 !!seconds!! i have low signal on booth decks at the same time. It's not maya44 because it is working on desktop.
It's not VDJ because i have the same problem playing with WMP through maya44.
I use TCVs with lastest drivers (2.5.5).
I think i will have to carry desktop around when i want to mix with vinyls.
It seems nobody can help me with this. I will try to reinstall windows (last chance).
Btw listen2:
check for lastest drivers of soundcard
Dj Nikki
Btw listen2:
Dj Nikki
geposted Mon 13 Jun 05 @ 2:53 pm
its funny because i connect my other card a creative with drivers from 2002 and i dont get this issue,i just can't verify anything since i can only test 1 deck at a time, it could it both as yours
geposted Mon 13 Jun 05 @ 3:56 pm
