1- How to make a button that cycles through three modes of video crossfader:
mode 1: crossfader is audio only, video is not affected
mode2: automatic video cross-fader : video transition goes always smoothly when crossfader is moved
mode3: manual video-crossfader: audio and video are crossfaded manually by crossfader
2. I have a button for brake effect while pressed. The problem is that sometimes when effect slider is in wrong position and I press brake effect, deck stops playing immediately. Can I make script for button that while_pressed, sets effect slider 1 to 100% then activate brake function?
3. I have effect slider 1 assigned to a knob going from value 0% to 100% as usually. But is it possible to have script that when I use cut effect, it would go only 50%-100%? Because cut effect sounds bad when effect slider goes below 50%.
PS. There should be a dedicated forum for the script advices!
geposted Tue 31 Aug 10 @ 8:12 am
Have you looked at the "dedicated script" section here, https://virtualdj.com/wiki/VDJscript.html. lmao!! Click on "the list of verbs" it should help you out.
Huey
Huey
geposted Tue 31 Aug 10 @ 10:04 am
geposted Wed 01 Sep 10 @ 1:07 pm
I still need help with these! :/
geposted Thu 09 Sep 10 @ 12:22 am
