After returning the DDM4000 as the stupid thing wouldn't work after i got it out the box, i'm looking for a 2 channel mixer.
I'm leaning to scratch, so a sharp cross fade would be a bonus. I'd like it to have all the EQ's and i mix hip hop and R&B stuff.
If possible, i'd like it to have some sort of effects on it + could possibly be used as a midi (though, not essential)
I've got a budget of around £250.
Thanks
Thanks
geposted Sun 05 Sep 10 @ 4:54 pm
https://virtualdj.com/forums/133639/General_Discussion/Anyone_using_Vestax_PMC-05-PRO4__.html, its not in your budget but check it out anyways.
Huey
Huey
geposted Sun 05 Sep 10 @ 5:08 pm
not sure on the USD ex-change rate but that doesn't seem like a whole lot of $$ for what your asking for. ANY decent professional mixer/midi controller is gonna be $500 + i would suggest save up a bit more to increase your budget so you don't end up making a similar purchase as with the DDM4000.
geposted Mon 06 Sep 10 @ 10:06 am
Yes, the DDM was a fail lol.
Not liking that Vastex one i'm affraid. Its horrid and seriouslyt out my budget lol.
geposted Tue 07 Sep 10 @ 12:53 pm
SO why not get another DDM4000, I have owned 3 of them and I never had the problem you described. You were just unlucky and got a bad one that couldn't enter the system setup menu. You will not be able to find much more options at that price.
geposted Tue 07 Sep 10 @ 1:25 pm
Barhanger have a bad name as it is, i was holding my breath when i bought it.
If its got a bad rep and it goes wrong with in 10 minutes, you know the rest of their products are crap.
I have decided not to go Midi base any more, it costs far too much money and theres not wide enough market.
I like the Stanton M.207 due to the fact it is tight and has Pan :D, how cool.
On the otherhand, kill switches near the crossfader would be a advantage too.
No longer interested in Midi
Thanks
Thanks
geposted Tue 07 Sep 10 @ 1:32 pm
Not too fussed if it has effects either. A simple, quality mixer.
Have been suggested Nuo 2.0 ? Quality, long lasting?
geposted Tue 07 Sep 10 @ 1:43 pm
i have been looking at the Numark X6, i have the M2 now and i think it is decent. The X6 has kill switches on the bottom part of the mixer.
geposted Tue 07 Sep 10 @ 2:13 pm
i have a numark DXM06 (i used it a week or two before i got my DDM4000) $150.00 USD
i have a Pioneer DJM600 (like new, not even one scratch) $549.00 USD
pm me if any interest
geposted Tue 07 Sep 10 @ 2:57 pm
I'm with the others. I would try for another DDM 4000. I, like you, had my reservations about Behringer period, as the mixer I was replacing was a Behringer DJX700 (UGH!!!!!)...I am in LOVE with my DDM. It still has some limitations when it comes to the big budget, industry standards that the DDM must face. But I figured that a MIDI mixer with XLR outs, customizable output solutions, including XLR out with sub, and the myriad of customization options available before you even get to the VDJ MIDI options, I could live with what it CAN'T do, and not worry about what others are going and the equipment they were doing it on.
geposted Tue 07 Sep 10 @ 5:19 pm
1) I don't need such a huge mixer
2) I dont need 4 channels any more, i'm getting rid of the RMX
3) Seriously, who needs effects when they can mix flawlessly ;)
4) I'd rather mix like DJ AM for example, a sharp mixer is required.
geposted Tue 07 Sep 10 @ 5:24 pm
Well I'd look for a Vestax (1 of the best, of course)!! http://pro-audio.musiciansfriend.com/product/Vestax-PMC06Pro-2Channel-DJ-Mixer?sku=632023&ZYXSEM=0&src=3AGGWXX2, you cant go wrong plus its in your price range!! Its just a staight up mixer non of that other crap and the fader is like BUTTER, nuff said, now enjoy...............lmao!! I'm playin. But foreal this is a sweet mixer.
Hope this helps
Huey
Hope this helps
Huey
geposted Wed 08 Sep 10 @ 12:29 am
thanks huey.
I've been looking at that mixer too, just not got round to reading review's.
geposted Wed 08 Sep 10 @ 8:11 am
