Whenever I scratch into the beat it shuts itself off. I tried reinstalling, I tried different music, different formats. Any suggestions?
Comp Spec
AMD Athlon XP 2500+
512 DDR PC3200
120 GIG Seagate HD 7,200RPM
Comp Spec
AMD Athlon XP 2500+
512 DDR PC3200
geposted Wed 20 Aug 03 @ 5:40 pm
Your computer specs seem ok to me. Do you have lots of other applications or services running?
What you could do to make sure it's not your computer, is to install windows 2000 on a separate harddrive, with no additional software.
So you keep your current setup for backup on the harddrive your currently are using.
Another suggestion is to read in the Bug report or technical questions forum, to see it's not a common issue
Ewout
Ewout
geposted Wed 20 Aug 03 @ 7:59 pm
