I am using Virtual DJ Pro v. 6.0.1 on a mac.
On certain skins, I have problems seeing the text that should go for song title, bpm and/or loop set. What I see are "A"'s in boxes displayed where the text should go. For example on Mix Lab 3.0, I can see the song title text, but I have the "A"'s in boxes for loop set and the pitch display.
I am assuming I am missing a font, but I can't seem to figure out how to fix it. I have uninstalled, deleted all the virtual dj files, fresh installed virtual dj and I still have the same problem.
Any help would be appreciated.
geposted Sun 12 Sep 10 @ 6:23 pm
I am having the same problem did you figure it out?
geposted Fri 15 Oct 10 @ 2:03 pm
I have the same problem as well. It was working perfectly until today when the font just got all messed up. Any help would be GREATLY appreciated.
geposted Mon 10 Jan 11 @ 4:08 pm
Anyone?
geposted Tue 11 Jan 11 @ 4:45 pm
No ;-)
Deinstall your actual versions and try to use the Home Free from here.
https://virtualdj.com/download/free.html
You will see it works.
BTW, at the moment the actual version is 7.0.2.
geposted Wed 12 Jan 11 @ 3:25 am
