Forum: VirtualDJ Skins
Topic: Skins at 1366x768
Hi,
Is there any skins with a resolution of 1366x768 as that is the re of my laptop
I would prefer the vdj 6 skin in this res as i like the default one.
Thanks in advance
geposted Tue 14 Sep 10 @ 7:16 pm
Why do you have to download something to make changes on the skin size. This is one of the things in my list that i don't like about virtual dj. Traktor doesn't do this or serato.. It open's up and adjust to any resolution you have it set on.
Thats because traktor and serato are better than virtual dj
DJ azen wrote :
you could use the Skin Resizer Tool to change the size of any skin i changed the 1280x800 skins to 1366x768 (that's my laptop resolution)
if you need help just pm me.
https://virtualdj.com/addons/7187/Skin_Resizer_Tool.html
when using this tool do i use option smart resize (beta) or simple resize
Is this a criteria to name one software better than another?
Lets put it otherways.... What do you prefer? To have just 1 skin with no ability to change anything, or to be able to choose from tens or hundrends skins and to be able to modify it to your needs?
the best option is simple resize
I used to have a laptop 1280x800 resolution the motherboard don't work anymore so I bought a 1366x768 lap ,i been resizing all my 1280x800 to 1366x768 i tried everything in the tool and the best option is the simple resize
Ok none of your above methods work.
1. the default skin does not have 1280x800 but has 1280x768
2. when i resize using the 1280x768 skin to 1366x768 no matter what settings i use in the skin resize tool the quility is drastic, both vinyls have loads of distorted lines.
Below is simple resize.
And this one is smart resize
And this is default 1280x768
I dont have license :(
Use Add borders if you don't want the picture to be altered.
Or send me an email and I'll see what I can do.
Ok i have selected add borders and everything seems to be ok. I cant see my desktop either side now nor is my taskbar onto of vdj now
