Hi, I've recently installed Virtual DJ - packaged with a Hercules Steel Controller - on my Macbook Pro. I'm finding that whenever I close the programme none of the BPM info is saved. I've looked for advice elsewhere on this forum which hinges on the database file (something like Virtual DJ5 Database.xml). I've checked in my Virtual DJ folder within My Documents and I have no such file. In fact I've searched my whole computer and found nothing of that name. Could anyone help me to locate or establish such a file?
BTW - I'm using the LE version and have switched to the 20-day Pro trial, still without joy.
Thanks in advance for any help.
geposted Fri 17 Sep 10 @ 9:47 am
It's a permissions issue ..... Chris has posted a solution here:
https://virtualdj.com/forums/121496/MAC_Version_Technical_Support/Database_not_saving.html?search=permissions&page=1
geposted Fri 17 Sep 10 @ 11:48 am
Thanks. Problem solved!
geposted Sat 18 Sep 10 @ 1:15 am
