Think I jammed all the details in the title. =) Is anyone else having this issue.
First note of trouble was when I activated the sonique plugin, I noticed that transparency control was not working, I could not fade the plugin. After dragging the transparency slider back and forth a few times VDJ froze completely, and closed. This happened twice. After a restart, activating the plugin had no effect at all, even though all the controls are showing, and so are all the other plugins (Appearing and working)
Using win7 pro on a HP DV6.
geposted Thu 23 Sep 10 @ 7:39 am
are you using the revised sonique pack only, try deleting and then reinstalling.
if you are using more than the sonique pack get rid of all the other crap then just do the above.
geposted Thu 23 Sep 10 @ 10:17 am
Pretty sure I have Cels latest pack only, plus some of mny own removed that I didn't like. Either way, I wouldn't think a bad svp file would also cause the transparency to mess up?
geposted Thu 23 Sep 10 @ 10:32 am
have you tried reinstalling the pluginn yet
geposted Thu 23 Sep 10 @ 10:58 am
Not as yet, Mon and tues are days off. =)
geposted Mon 27 Sep 10 @ 2:35 am
