I have a suggestion: having the option of autogain for the sample banks. I believe that it would help a lot.
Regards and thank you all.
geposted Wed 29 Sep 10 @ 8:21 pm
+ 1
geposted Thu 30 Sep 10 @ 2:40 pm
I think with the ability to have 99 decks I would say it pretty much solves that problem.... ;-)
Huey
Huey
geposted Thu 30 Sep 10 @ 3:07 pm
If the samples are treated as a track the auto-gain option will apply of course...Not shure if it will be like that, it will be kind of cool the explore samples as a track (eq. effect,etc.)
geposted Thu 30 Sep 10 @ 6:26 pm
Agree Luis. For sure we can treat samples as tracks by simply uploading it into deck 1 or 2. Maybe having much more (99 or 4?) decks, as suggested... The problem is that sometimes samples are too short to treat it as a full song (for example, a siren). In addition, if you have the autogain for samplers, you can use samples in the same time we are mixing two (or more with VDJ7?), i.e., you can upload a new sample without worries about if this or that sample was recorded using higher or lower recording levels. It would make the live sets creation easier. Let's try VDJ7 before.
geposted Fri 01 Oct 10 @ 11:18 pm
