Does anyone know what would the operator be for a filter folder to filter "First Seen" between 9/1/2010 and 9/30/2010
geposted Thu 30 Sep 10 @ 5:20 pm
I tried everything I know but couldnt get it to work. I dont think you can get down to the day but try "top 100 firstseen and days since lastplay<31" It should give you the top 100 played from a month ago till the present. I think this might get you close.
Hope that helps
Huey
Hope that helps
Huey
geposted Thu 30 Sep 10 @ 5:54 pm
Thanks Huey :-)
geposted Thu 30 Sep 10 @ 6:09 pm
Hey Huey.. are Filter Folders supposed to stay and/or save when you close VDJ? I set up the filter.. closed VDJ.. relaunched and the folder is not there.
I restarted.. tried it again.. but same result :-(
Do I really need to set up a filter every time?
geposted Fri 01 Oct 10 @ 2:33 pm
No they should be there every time you open VDJ. I've never had that happen to me but I think I read about that happening in the general forum. Just curious how did that command work for you? Hopefully some what close to what you wanted, lol!!
Huey
Huey
geposted Fri 01 Oct 10 @ 2:54 pm
once i changed the 100 to 300 yeah hahahaha i'm a download junkie! :-)
now if I can just figure how to get the folder to STAY.. guess I'll create a NEW topic for that prob..
geposted Fri 01 Oct 10 @ 3:06 pm
Yo bro check this thread, its what you want, https://virtualdj.com/forums/135241/General_Discussion/Date_Based_Filter_Folders____.html
Enjoy
Huey
Enjoy
Huey
geposted Wed 06 Oct 10 @ 10:51 pm
Thanks for the heads up Huey!!!
This leads me to another question since my Filter Folders are quickly adding up.. Can Filter Folders be nested?
I'm not sure if that's the right term or not but what I would like to do is have a "Main" folder titled "Downloads 2010" with a PLUS sign next to it. If I click on that PLUS sign the folder expands and I see ALL 12 Filter Folders for that year below it by MONTH i.e. 01/10 through 12/10
Any advice?
Any advice?
geposted Fri 08 Oct 10 @ 10:55 am
Right now you can't have nested folders. However I believe that someone from the team said on the wishes forum that VDJ7 will allow you to have nested folders...
geposted Fri 08 Oct 10 @ 11:04 am
