OK for those that have downloaded nows the time for "likes and dislikes" about the skin...................I wanna start on v.2 but would like to hear some input from people who have used it.
Thanks for your time
Huey
Huey
geposted Mon 01 Nov 10 @ 11:58 pm
Hi Huey,
thanks for this realy great skin. Here a few suggestions & questions from me:
- I would like to see to buttons over/under pitch-rest with deck nr pitch +/- 0,05% (like Mix-Lab 3)
- why the sliders not in 2D? like a line for example?
- Is ther a way to change the loop/sampler-panel for deck 1&2 (didn't found it)? I would toggle the panels through one click, I mean 1 button for each deck
- I would prefer rightcklick to rename cue, double-right to del.
If you change the waveform to buttom-down, you're unable to see the cue-point.
BTW: Masterdeck is missing (or I didn't found it).
Thanks for all the hard work, I would be glad if I could make a skin like you.
Sorry for my bad English.
Best regards ;o)
Music234
Best regards ;o)
Music234
geposted Tue 02 Nov 10 @ 2:03 am
Music234
Music234
I dont know what this means. Can you give me a better example of what you mean?
And your english is fine bro!!
Huey
geposted Tue 02 Nov 10 @ 9:19 pm
Nice to hear that ;o)
Try to visualize my thought:
...but he, it's only a suggestion.
Greets
geposted Wed 03 Nov 10 @ 1:39 am
Your idea's not bad music234... But for me, only if it doesn't use more RAM... I like efficacity and stability more than gadgets
geposted Wed 03 Nov 10 @ 2:33 am
Those 2 pitch sliders are both 2D. and certainely has noting to do with RAM. Its only graphics mates. We dont build 3d graphics. Simply some 2d graphics look like 3d but they are fake. So its just a matter of taste. You still are able to edit the bmp according to your styles.
geposted Wed 03 Nov 10 @ 9:04 am
You're right. Imo the style of the skin is 2D. That`s what I mean.
;o)
geposted Wed 03 Nov 10 @ 9:22 am
Ok version 2 is almost complete. Any other input from y'all?
Huey
Huey
geposted Thu 04 Nov 10 @ 10:17 am
Cool... Really Cool !
geposted Thu 04 Nov 10 @ 12:30 pm
Nice to hear this ;o)
geposted Thu 04 Nov 10 @ 1:03 pm
Sweet Scratch x4 v.2
https://virtualdj.com/addons/12095/Sweet_Scratch_x4.html
Now Ready
New Features:
A "Master Deck" button on each deck
For the "Cue" buttons, "Left Click" sets the cue point, "Double Click" deletes the cue point, "Right Click" to rename the cue point (Might make the name visible on the buttons, let me know)
3 different "Rhythm Waves"
Rhythm Wave can be "Turned OFF"
All 4 decks now have a Sampler Record station (The button for decks 1 and 3 is next to the "Mixer" button, for decks 2 and 4 its next to the "Settings" button, "Left Click" Loop station/ "Right Click" Sampler station)
Added "SBDJ Battery Status Plugin", This will tell you your battery % and will flash when your Laptop becomes unplugged (Big UPS to SCOTT for this 1!! YOU MUST DOWNLOAD AND INSTALL THE PLUGIN FOR IT TO WORK!! YOU CAN GET IT FROM "WWW.VIRTUALDJ.COM")
Deck "3" and "4" support "LINEIN" and "MIC" meaning to turn your MIC VOLUME down you use either Deck 3 or 4 which ever you have turned on and yes when using the MIC's you can apply that decks effects to your voice (This is too Fresh!! My kids wont leave me alone once I showed them that!! lol!)
A "TalkOver" button, "Right Click" to use it as a TalkOver Switch, "Left Click" keeps the Mic on, (This is only on DECK 4's MIC!!)
Added a "Save Deck Set" and "Load Deck Set" buttons (I love this feature)
I wanna THANK everybody that has downloaded the skin so far!! A Huge thanks to DJ FANDOS for giving me the foundation to create this skin. Big ups to Listen2, SSLover for creating some of the first scratch skins!! Big ups to DJTouchDan, DJDad for all the help!!
Enjoy
And as always if theres something you dont like or think the skin should have let me know and I'll see what I can do..........
Huey
Now Ready
New Features:
Enjoy
Huey
geposted Fri 05 Nov 10 @ 7:02 pm
Ok found a little bug. Im gonna have to change the delete cue, well how it deletes cue points anyways. What happens is if you hit you cue point really fast it'll delete then add it then delete it. So I would say don't hit the cue buttons fast. Ill upload the fix tonight. The fix will be you'll have to hold the button down for a set number of milla seconds, lol!
Sorry for any problems this has caused you
Huey
Huey
geposted Sat 06 Nov 10 @ 8:16 am
OK new version with the fix is uploaded and ready to go.
To set a cue point "Left Click", to name a cue point "Right Click", to delete a cue point "HOLD the Right Click" down.
Again sorry for any problems this has caused
Huey
Huey
geposted Sat 06 Nov 10 @ 3:37 pm
Nice skin. I am trying to modify the skin to add the beatgrid. Can someone guide me on how to do that on that skin?
geposted Sat 06 Nov 10 @ 9:59 pm
It already has the beat grid, its right below the waveform. If you dont see it click on the button in the top right corner that says "WAVE" until you see the grid. 1 of the waves doesnt show it.
Hope that helps
Huey
Hope that helps
Huey
geposted Sun 07 Nov 10 @ 12:41 am
beatbreaker1, thank you. I will try that!
Wait, the wave option you are talking about does not show on the skin that I have at all.
OK. I was still using an older skin now I know. Thank you.
geposted Sun 07 Nov 10 @ 8:48 am
Yeah I just updated the skin, added a few more things.
Hope you like
Huey
Hope you like
Huey
geposted Sun 07 Nov 10 @ 9:21 am
beatbreaker1, thank you for the skin. The only thing I would prefer from the skin because I don' t use midi mixer is the channel fade buttons to be sliders instead of rotators.
geposted Sun 07 Nov 10 @ 9:40 am
Hi Huey,
pretty cool skin ;o)
Thanks a lot for this masterpiece.
Greets
Music234
Greets
Music234
geposted Sun 07 Nov 10 @ 3:22 pm
Hi Beatbreaker1
Very done job and skin.....
I will post some wishes for the version "sweet scratch x4 v3. "
Could you please implentate the four informations, as the newiest skin from DJ Fandos in the jogwhleels:
https://virtualdj.com/forums/134696/Virtual_DJ_Skins/my_scratch_skin.html?search=dj%20fandos&page=1
- What about the four colours from the following skin. I think they are very good. ( 1st Deck: Blue, 2nd: Red, 3rd: Green, 4th: Yellow)
https://virtualdj.com/addons/12114/VirtualDJ_7_%284_Decks%29.html
Many thanks for your job....
chris
chris
geposted Mon 08 Nov 10 @ 5:56 am
