Forum: Old versions
Topic: Gemini Ctrl Six
HELLO. IS THERE A CHANCE TO GET A VDJ MAPPER FOR THE GEMINI CTRL SIX CONTROLLER ? THANK YOU
geposted Mon 04 Oct 10 @ 3:30 pm
I believe we are working on a mapper for that unit and should be in the next version release.
is this mapper available now? i just bought a ctrl six and its kinda difficult to use with virtual :S
The mapper is already built into the software (Including the LE that came with the CTRL SIX.)
If you would like to customise it to suit your own preferences, you will need to upgrade to the full VirtualDJ Professional: https://virtualdj.com/buy/
You can test out mapping in the 20 day Pro trial if you have not already used this or you can test it for 10 minutes at time in VirtualDJ Home FREE: https://virtualdj.com/download/free.html
Hi.
I have Gemini ctrl six and install cd. They both have same serial number.
After I downloaded app, I can not open the file. every time I type in serial number, it keep tells me "invalid serial number"
