Hi,
Could you help me how to read delta from current and previous knob/slider value and use it as paramter for command?
E.g. how to read delta between current and previous crossfader position and use it to set e.g. pitch value?
Thanks for help.
Thanks for help.
geposted Wed 06 Oct 10 @ 12:39 pm
Hmm, interesting. I dont believe VDJ has a delta measurement. You would have to "get_XXX" and than "get_XXX" after the adjustment. VDJ will not store that change data but if you annotate it, you can specify the change when you press/release a key/button.
geposted Wed 06 Oct 10 @ 3:45 pm
I need to do something like this:
delta=slider_var-old_var
pitch=delta
old_var=slider_var
or
pitch=slider_var-old_var
old_var=slider_var
where:
slider_var - current slider var
old_var - defined variable
but I don't know how to write it in VDJscript
pitch=delta
old_var=slider_var
or
old_var=slider_var
where:
geposted Thu 07 Oct 10 @ 2:08 pm
