Guys be sure to look here: http://www.denondj.com/assets/misc/S3700_v2000_with_VDJ_6.12.zip
You need this def file so VirtualDJ will detect your 3700.
geposted Thu 07 Oct 10 @ 10:07 pm
Haven't had much luck with the Hybrid midi but can report that the regular midi mode is working as expected in VirtualDJ with the new device.xml
geposted Fri 08 Oct 10 @ 11:32 am
how do you add the new device S3700v7.xml
geposted Fri 08 Oct 10 @ 4:39 pm
Copy the file into Documents/VirtualDJ/Devices
geposted Fri 08 Oct 10 @ 7:01 pm
After I updated the firmware in my 1200s to 3000, VDJ will not identify my 1200s in midi mode. What am I doing wrong?
geposted Sat 09 Oct 10 @ 4:41 pm
geposted Sat 09 Oct 10 @ 11:39 pm
@Denon DJ, can you give me a list of your cdj's with a Spinning Platter?
Thanks for the time and info
Huey
Huey
geposted Mon 11 Oct 10 @ 8:44 am
whats the midi settings? my 2 player work on unit set 1 befor i use to set left deck on 1 and right deck on 2 dose not work like dat any more 2 player has to be on 1
geposted Mon 11 Oct 10 @ 10:28 am
just whant tto say thanks for helping me out man.
whats the midi settings? my 2 player work on unit set 1 befor i use to set left deck on 1 and right deck on 2 dose not work like dat any more 2 player has to be on 1.
and the denon mapper is so hard to get dam.....
geposted Mon 11 Oct 10 @ 10:31 am
Huey
Huey
There is only 1
DN-S3700
geposted Mon 11 Oct 10 @ 11:17 am
Set both decks to MIDI CH 1
Load the provided and new xml file into the device folder
set players to midi mode
start VDJ 6.12
That it, should work .
geposted Mon 11 Oct 10 @ 11:19 am
anyone has the denon mapper for virtual dj drop me a link
geposted Mon 11 Oct 10 @ 1:27 pm
Denon DJ wrote :
geposted Mon 11 Oct 10 @ 2:32 pm
Hi to all :)
I'm testing my 3700s with new hybrid firmware but no have audio device to test it with timecode, so i'm trying in simple midi.
I modified xml definition file because it define 1480 pulse and not 2940 as mentioned....
But Vdj does not work well and i have continues drop-out , but the difference of the platter resolution is evident.
I wonder if this is a limit of Vdj or a limit of MIDI protocol
thanks.
thanks.
geposted Tue 12 Oct 10 @ 4:19 am
HACKID wrote :
Hi to all :)
Ciao Hackid.
Its 2960, not 2940
VDJ Team would need to recode and tweak for 2960
Quote :
Its not a limit of the MIDI protocol, the player provides high resolution MIDI with timestamps.
geposted Tue 12 Oct 10 @ 12:16 pm
Hi Mr. Zeppieri :)
Thanks for response....
Today I tested it with my new HP ENVY (i7 720,6gb ram) :
DENON ASIO DRIVER
EXT MIXER
LATENCY 1MS
no problem! very good sound and realist scratch.... Only limit is still platter resolution bacause pitch-banding is not possibile using hand but only with button + - ...
I hope Team surpass this limitation....
Denon dns3700 with high resolution platter is as TECH 1200!!!
was a typo :)
20 steps make no difference eheh.
DENON ASIO DRIVER
EXT MIXER
LATENCY 1MS
Denon DJ wrote :
Its 2960, not 2940
was a typo :)
geposted Tue 12 Oct 10 @ 12:41 pm
thanks for all the help
geposted Wed 13 Oct 10 @ 6:11 am
what the difference virtual pro vdj home
geposted Wed 13 Oct 10 @ 3:29 pm
@denon-dj
hi ihave updated now one player and it could not connect in midi restarting the hole things vdj an 3700 bring no efect player is recocniced as simple midi config xml in plase or not no diffrenz setup is win7ultimate 64 vdj7 one dn-s3700 with new firmware (at the moment)please addvice
thanks dj-agua
thanks dj-agua
geposted Wed 13 Oct 10 @ 5:10 pm
Please see https://virtualdj.com/products/comparison.html
geposted Wed 13 Oct 10 @ 7:43 pm
