ok, I know I need the pro versionto remap my Control Steel but...
is there another way? I can't pay the pro license =(
And I heard ppl that remap their steel without any license
geposted Sat 09 Oct 10 @ 3:26 pm
Hello zedjcr3me,
You can use the application called "MIDI Mapper" which alllows you to remap your controller regarding your needs.
Once installed you can launch it from Start>>Progam>>Hercules>>DJ Audio>>MIDI mapper.
You have also a user manual accessible from Progam>>Hercules>>DJ Audio>>MIDI mapper>>User manual or in
the "Help" menu and select "Open Manual". It should help you to understand how it works.
You can download the application here:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=61&pid=226&cid=4
geposted Mon 11 Oct 10 @ 3:58 am
That utility will only allow you to modify the MIDI messages that buttons send, e.g: You could swap the functions of two buttons with each other.
However, it will not allow you to change the VirtualDJ function assigned to each button. This is only possible in the full VirtualDJ Pro https://virtualdj.com/buy/ or with the free the trial of VirtualDJ Pro https://virtualdj.com/download/trial.html
Your Steel DJ Console entitles you to a significant discount off upgrading to VirtualDJ Professional. To receive this, please go to https://virtualdj.com/buy/ and enter your DJ Console software serial number in the box provided.
NOTE: Care should be taken with the above utility because if you change the MIDI messages sent by the buttons to something not recognised by VirtualDJ, then it will no-longer work.
geposted Mon 11 Oct 10 @ 4:14 am
