previous to version 3.0 once the track is done, it goes back to beginning of song, but in version 3 it empty's the deck, is there anyway to change this so it keeps finished track in the deck? sometimes I like to bring a song back in once it has been complete.
thanks
thanks
geposted Mon 20 Jun 05 @ 4:01 am
This is not so. The only time I have every seen the scenerio you described is if you have the Automix on from the playlist and there are no tracks to be loaded.
cstoll
Edited:
Just verified it. Drop two tracks on the decks, click on the "star" icon in the playlist, jump the track that starts playing to almost the end, then watch VDJ automix. The deck that just finished disappears. Now repeat the process, but after you press the "star" to start the automix, then click the "star" again to turn it off. The deck that began will end and stay in the deck.
Hope this helps,
cstoll
cstoll
Edited:
Hope this helps,
cstoll
geposted Mon 20 Jun 05 @ 11:25 pm
ahh, didnt realize i had clicked the automix button, on default skin, i had since switched to the pioneer2 skin and did not notice.
thanks a bunch.. appreciate it!
geposted Tue 21 Jun 05 @ 2:54 am
