Does anyone use this soundcard with VDJ?
If so can you tell me your internal settings; i.e. 5.1,7.1, 3dsurround........
I want to make sure I am getting the best possible sound out of it.
Thanks
Craig
Thanks
Craig
geposted Mon 20 Jun 05 @ 2:51 pm
I use this card. My setting is 4.1 Quadraphonie.
geposted Tue 21 Jun 05 @ 5:03 pm
I use it too. Without ASIO you could use it as 5.1 or above to use more output channels. You most configure your soundcard first, then select the proper options in VDJ. Use the soundcard software to change the output settings before use or select in VDJ (to change it to 5.1 for example). If you don't do that, the soundcard doesn't work with headphones or with the output sound channels mixed. I couldn't work fine with 2.1 or 4.1 option, I haved mixed the output channels.
I have some issues with this card in ASIO mode, you could check it here:
https://virtualdj.com/forum/display.html?topic=11856
and
https://virtualdj.com/forum/display.html?topic=13066
and
geposted Thu 23 Jun 05 @ 5:55 am
