How to assign a script to keep deck 1 as the master deck no matter if you load or unload any other decks?
geposted Wed 13 Oct 10 @ 3:54 pm
Why do you wanna do this? You will have sync issues among others...
anyway if that helps you..
masterdeck off & deck 1 masterdeck or just deck 1 masterdeck should be fine. Other option is to hit the masterdeck skin button on deck 1 (if deck 1 is masterdeck) on a skin that has masterdeck buttons. Once you hit it masterdeck (automatic way) is off. If you want to enable the automatic way again just press it once more.
geposted Wed 13 Oct 10 @ 5:35 pm
I am actually trying to prevent those sync issues that i have when I ma using all 4 decks.
geposted Wed 13 Oct 10 @ 8:31 pm
DJdad, do you know if there is a way to show on a skin if the Masterdeck auto switching is enabled or not?
On the stock skins there seems to be no indication of whether it is locked or whether it auto-switches when a deck is paused or level is reduced.
Edit:
I've created another thread for this in skin skins section since it's more relevant there.
https://virtualdj.com/forums/137074/Virtual_DJ_Skins/Showing_Masterdeck_mode_status_in_a_skin_(or_controller).html
Edit:
geposted Sat 06 Nov 10 @ 8:42 am
