It seems when recording a mix session the new version is recording the deck playing and the deck I'm cueing. Now had the system set up as follows:
Input: None
Output: External Mixer
Sound: ASIO (Pioneer)
I'm using A DJM 800 Mixer and 2 CDJ 400's.
Now I've read the Audio Set Up Guide Book, but thats not helping either with Advanced Config as I've tried to set it up as this:
Deck 1 - Pioneer ASIO - Output 1&2
Deck 2 - Pioneer ASIO - Output 3&4
Reloop Record - Primary Recording Device - Output 1&2
In this mode the decks become scratchy and recording is horibble.
Any help please.
Thanks Lo
Input: None
Any help please.
Thanks Lo
geposted Wed 13 Oct 10 @ 7:24 pm
Bump
geposted Thu 14 Oct 10 @ 9:29 am
anyone interested in providing an answer.. ?
geposted Thu 14 Oct 10 @ 11:36 pm
Any help from the VDJ gods please.................................
geposted Fri 15 Oct 10 @ 1:23 pm
Hi,
what recording options have you got?
geposted Fri 15 Oct 10 @ 2:48 pm
Sorry, my mistake, the settings have gone in v7
geposted Fri 15 Oct 10 @ 2:57 pm
Are you running an output from your Mixer to a Line Input your built-in soundcard?
geposted Fri 15 Oct 10 @ 3:01 pm
to record from "line in" in VDJ 7, choose RECORD LOOPBACK in advanced sound config.
geposted Fri 15 Oct 10 @ 3:52 pm
Yes its from my record out from my mixer to the laptop mic input.
geposted Fri 15 Oct 10 @ 4:09 pm
hum..
For record loopback you are using line in at your PC right? so it should be INPUT .. not output.. (i think)
Anyways, it might be too many asio devices..
Either try set a higher latency in pioneer asio, OR if possible use non asio (think Pioneer drivers support that)
geposted Fri 15 Oct 10 @ 4:22 pm
hum..
hum..
Yes, it goes from my mixer back into the laptop via the Mic input on the front. Now when i try it as input it says not enough channels. VDJ 6.xx never had an issue with it and had it set as follows;
Input: None
Sound: ASIO
geposted Fri 15 Oct 10 @ 6:32 pm
Bump
geposted Sun 24 Oct 10 @ 12:53 am
at DjLo
im having the same problem so i finally ran across this post that may help,,,i have to go get the cable i will post back if it works
https://virtualdj.com/homepage/jpboggis/blogs/4135/Recording_your_set_or_broadcasting_when_using_an_external_DJ_%3Cspan%20style=
geposted Fri 05 Nov 10 @ 6:53 pm
ok so what i did was run my record out to my mic line in, but i had to go into my computer sound config and run record under mic not line in..but curretnly im running 6.x..now i have to get it in stereo..but it may be the adapter i used as it was one i just had in the house,,,
geposted Sat 06 Nov 10 @ 10:31 am
