So now that there are 99 decks available. I would like to do a simple task and can not seem to get it right. I use a VCI-300, I set the assignment on the controller to LEFT and RIGHT respectively. All I want to do is remap my CRATES button so when it when pressed it swaps between deck 1 to deck 3 and the BROWSE button deck 2 to deck 4. But I want all the controls to swap (PITCH, VOLUME, JOGWHEEL, PFL) I would have thought there would be a simple command to do that I did notice "invert controller" will cycle through all the decks but I would prefer only the 2 respective to the LEFT or RIGHT, I guess the same effect as using the mouse and clicking LEFT or RIGHT on the bottom left of the decks. Maybe if the command does not exist it a decent suggestion something like "swap_active deck 1 & 2" or "deck 1 & deck 3 left deck" something to that effect.
geposted Thu 14 Oct 10 @ 6:43 am
You need to dedicate one button for deck and map:
and its led:
and when deck 3 or 4 will be active the led will be ON.
device_side left ? deck 1 leftdeck ? deck 3 leftdeck : deck 1 leftdeck : deck 2 rightdeck ? deck 4 rightdeck : deck 2 rightdeck
and its led:
device_side left ? deck 3 leftdeck : deck 4 rightdeck
geposted Thu 14 Oct 10 @ 9:44 am
and its led:
and its led:
This never worked for me but the following accomplished exactly what I wanted, you pointed me on the right track thanks:
I have VCI 300 so i mapped:
CRATES to deck 1 leftdeck ? deck 3 leftdeck : deck 1 leftdeck
LED_CRATES to device_side ? deck 1 leftdeck : deck 3 leftdeck
AND
BROWSE to deck 2 rightdeck ? deck 4 rightdeck : deck 2 rightdeck
LED_BROWSE to device_side ? deck 2 rightdeck : deck 4 rightdeck
geposted Tue 19 Oct 10 @ 4:07 pm
Or even better, that makes the deck you swap to also the active deck, putting the waveform in front, as well as turn that deck to the deck you control with a 2 deck controller (like VCI-300)
deck 1 leftdeck ? deck 3 leftdeck & deck 3 select : deck 1 leftdeck & deck 1 select
deck 2 rigthdeck ? deck 4 rigthdeck & deck 4 select : deck 2 rigthdeck & deck 2 select
geposted Tue 19 Oct 10 @ 10:13 pm
