Before Virtual Dj And Hercules Rmx I used to useCDJ 500's & DJM. On the effects of the mixer was Echo and when you pressed pause on the Cdplayer then echo would carry onAfter the pause had been pressed. This was brilliant for mixing various tracks can we get an effect like that, or is one already out there that I've missed.
geposted Thu 14 Oct 10 @ 2:58 pm
As told in another topic, as for now you can use my EchoDoppler effect to do that. Just put the Dry/Wet slider in the middle in order to "sample", then move it to the maximum to let the track fade out.
It's more difficult to tell than to do ;-)
geposted Thu 14 Oct 10 @ 4:37 pm
But to answer your question there is an actual Echo Out effect in the download section its called" loopout",
Enjoy
Huey
Enjoy
Huey
geposted Thu 14 Oct 10 @ 4:41 pm
geposted Thu 14 Oct 10 @ 6:36 pm
