What encoder can I use with virtual dj 3.0. I have tried shoutcast, but I get an error saying "encoder error"
geposted Tue 21 Jun 05 @ 10:19 am
With shoutcast you need to specify an encoder, because it wont work by default, you should have a plugin called "LAME" in your virtual DJ folder, select the path and fire away.
There is a chance you don't have this file, as when I downloaded 3.0, this file disappeared, strange, contact e-services if that's the case.
Bagpuss.
Bagpuss.
geposted Tue 21 Jun 05 @ 1:32 pm
http://www.fortunecity.com/lavendar/birds/107/shoutcast.html
check tutorials like that ^^ (look around with google) for setting up shoutcast
or read what i have posted a while ago to stream with VDJ:
https://virtualdj.com/forum/display.html?topic=12809
geposted Tue 21 Jun 05 @ 7:21 pm
