Does anyone know how to map the VCI-100 to VDJ 7, so that 4 decks can be used. Traktor has the VCI-100 mapped for 4 decks so I'm sure it can be done.
geposted Fri 15 Oct 10 @ 8:12 pm
device_side left ? deck 1 leftdeck ? deck 3 leftdeck : deck 1 leftdeck : deck 2 rightdeck ? deck 4 rightdeck : deck 2 rightdeck
This is a code I used on my keylock buttons to switch back and forth on the left and right sides. You can choose any button that is common on both decks on the controller, but I never used my keylock buttons, so I used them for this task. It works great!
geposted Tue 19 Oct 10 @ 10:30 pm
Thanks but I'm not a programmer nor know where to begin. I can download the mapper only not change the configurations. Thanks but I think I'll wait for a complete mapping.
Bc
Bc
geposted Wed 20 Oct 10 @ 9:13 pm
There is no need for a special mapper like in Traktor. You just make a shortcut with the action descibed in the posting. Like 'F12' or whatever. With this Hotkey you can switch between the decks.
Greets, Heiko
Greets, Heiko
geposted Sat 23 Oct 10 @ 7:31 am
Where do I type/write this code ? Like step by step instructions would help
....and I want to use the 'cue' buttons (next to the 'low' knobs?
How do I do this?
Bc
How do I do this?
Bc
geposted Sat 06 Nov 10 @ 11:23 am
See https://virtualdj.com/homepage/jpboggis/blogs/4149/VDJscript_Mapping.html for steps on how to change or add a mapping.
The mapping that you will need can be found at the top of the following page: https://virtualdj.com/wiki/VDJScript%20Examples.html
Simply copy and paste it into the Action: box.
geposted Sat 06 Nov 10 @ 3:05 pm
