There is no way my 1.6ghz atom 2gb netbook can handle VDJ7 Advanced Master Tempo.
I want to buy a new laptop for VDJ7 and I want to fully utilize the brand new Advanced Master Tempo.
What are the technical requirements to use this new feature?
CPU?
RAM?
Admins & people in the know, your response is greatly appreciated!
CPU?
RAM?
geposted Sun 17 Oct 10 @ 7:40 pm
Your computer will need to meet and preferably exceed the recommended requirements at the bottom of the following page:
https://virtualdj.com/products/virtualdj/
geposted Mon 18 Oct 10 @ 8:23 am
thanks --- the old VDJ v6.x worked horribly on a netbook with Advanced Tempo... but VDJ 7 seems to take *less* resources!
however, there are also less options... there used to be 2 parameters you could change for 'quality'
(now it's just fast or advanced)
actualy, vdj7's Advanced Master tempo just barely works on a 1.6ghz atom netbook, for those who are curious
geposted Mon 18 Oct 10 @ 9:23 pm
Works great on a consumer grade 5.1 device on both XP and Windows 7.
But for Windows 7, you might need ASIO4ALL setup. At least on mine. But XP WDM works dandy.
geposted Mon 18 Oct 10 @ 10:30 pm
