Forum: Wishes and new features
Topic: quick grid correction button
im loving the new vdj 7 with 4 decks
and tend to use betlock with 2 decks and with the other 2 i used my time code so that i can remix all the time
(its not cheating if u use wicked mixes its the same thing but live :) )
and way some times the beat grid is work and i dont like speeding that much time fixing it
so i want a way to fix it on the fly by using my time code or midi matching the other songs bpm im mixing in to. then hit quick grid correction
then im done so no mater what the grid is where it should be .
geposted Mon 18 Oct 10 @ 4:45 pm
Depending on what skin your using, just click on the bpms once and it should correct it self.
Huey
The grid position on the rhythm view has to do with the way VirtualDJ analyzes a song. There is no automatic way to edit grid, you have to adjust cbg using shortcuts or skins with such features. You may also open the Edit BPM menu.
NEVER USED IT, I DON'T EVEN KNOW IT'S ACTUALY A VDJ FEATURE...
