here you go ;)
deck 2 timecode_active on ? deck 2 timecode_active off & deck 4 timecode_active on & deck 4 rightdeck & deck 4 select : deck 4 timecode_active on ? deck 4 timecode_active off & deck 2 timecode_active on & deck 2 rightdeck & deck 2 select
geposted Tue 19 Oct 10 @ 1:20 am
PURE GENIUS!! Thanks a million NORWAY! Cant nobody ever they dont get help around here, lol!!
Much Respect
Huey
Much Respect
Huey
geposted Tue 19 Oct 10 @ 7:24 am
LOL ... that's what i call support !!!!
geposted Tue 19 Oct 10 @ 11:02 am
yeah, very intresting! I need to read again everything from the beginning but I think i'll get it :D
geposted Tue 19 Oct 10 @ 2:51 pm
is this all one command?? I dont see it working...
geposted Thu 16 Dec 10 @ 9:31 pm
djdad wrote :
I really know just a few things about timecode so im not sure what are you trying to do..anyway if you need to toggle timecode_active
use this
deck 1 timecode_active ? deck 3 timecode_active : deck 1 timecode_active
and for the other 2 decks
deck 2 timecode_active ? deck 4 timecode_active : deck 4 timecode_active
use this
I cant get this to work. I asigned one to CTRL1 and one to CTRL2 and when I press them nothing happens with the time code. I dont se the time code button change to the other deck. HELP!
geposted Thu 16 Dec 10 @ 9:37 pm
This for decks 2 & 4
"deck 2 timecode_active on ? deck 2 timecode_active off & deck 4 timecode_active on & deck 4 rightdeck & deck 4 select : deck 4 timecode_active on ? deck 4 timecode_active off & deck 2 timecode_active on & deck 2 rightdeck & deck 2 select"
And this is for decks 1 & 3
"deck 1 timecode_active on ? deck 1 timecode_active off & deck 3 timecode_active on & deck 3 rightdeck & deck 3 select : deck 3 timecode_active on ? deck 3 timecode_active off & deck 1 timecode_active on & deck 1 rightdeck & deck 1 select"
As you can see DJ-IN-NORWAY sat up with us for like 3 hours going back and forth till we got it, lol!! But it does work and yes its all 1 long command. What skin are using also?
Huey
Huey
geposted Thu 16 Dec 10 @ 10:34 pm
