I NEED HELP ? I HAVE THE NUMARK MIXDECK AND I'M NOT SURE WHAT TO DO. THE MIXER ON THE MIXDECK IT SELF WORKS FINE WITH VRTUAL DJ SOFTWARE BUT THE PLATTERS ON THE MIXDECK WILL NOT WORK . IT ISNT CONTROLING THE SONG ON ETHER CHANNEL. PLEASE HELP I ONLY BOUGHT THE MIXDECK CAUSE I WAS TOLD BY THE SALESMAN THAT IT WOULD WORK WITH ANY DJ SOFTWARE OUT ON THE MARKET.
geposted Tue 19 Oct 10 @ 11:00 am
Which version of VirtualDJ are you using?
geposted Tue 19 Oct 10 @ 11:08 am
VIRTUAL DJ 6.0
geposted Tue 19 Oct 10 @ 11:20 am
That version is too old and does not support the MixDeck.
If you have purchased VirtualDJ Pro, please register your serial number https://virtualdj.com/users/edit.html and then upgrade for free to latest v7 Pro: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ, then please go to https://virtualdj.com/buy/
You can try out the MixDeck for 10 minutes in VirtualDJ Home FREE: https://virtualdj.com/download/free.html
geposted Tue 19 Oct 10 @ 11:29 am
hi there
i just purchased mixdeck frm numark & cue did all the up grades the only thing missing is the mapping where do i get it
pls let kno a.s.a.p. have a gig this friday
thanx elio
thanx elio
geposted Wed 12 Jan 11 @ 4:53 pm
It is built into the latest v7.0.2 version: https://virtualdj.com/download/updates.html
If you already have this installed and it is not working, make sure that you have the latest drivers and firmware installed from http://www.numark.com/mixdeck
geposted Thu 13 Jan 11 @ 5:28 am
