Forum: Old versions
Topic: Headset+speakers?
Ok firstly I should state what i want to do. I want to play Speakers through the rear-Output via Realtek and headset via a virtual audio cable with a front headphone jack. And know how to use it and set it up.
My multimedia output lines are:
Realtek High Definition Audio
Virtual Audio Cable
My desktop:
Dell Inc. Inspiron 530s
System Service Tag: H0MCZF1 (support for this PC)
Chassis Serial Number: H0MCZF1
Enclosure Type: Desktop
The Realtek is my soundcard I believe.
the virtual Audio Cable is a virtual Output line.
What I'm thinking is my speakers get hooked up to the line-out on the back of my PC.
And my headset gets plugged into the headphone jack in the front.
But i'm not sure how to do this. I don't know how I can select the Virtual Audio Cable as the default for the headphone jack (As-in speakers play through the rear Line-Out/Realtek while the headset plays through the headphone jack in the front via Virtual Audio Cable)
How can this be done?
And how do you work with the dual-output and dual sound card thing on Virtual DJ? I have the settings set up (Left side/Reatek right side/Virtual Audio, and I have the Line outs set up like that too)
but how do I work with it?
geposted Tue 19 Oct 10 @ 8:16 pm
You need the pro version for using more than one soundcard, and advanced soundcard settings.
With pro version you can do anything ;)
You can upgrade to pro, probably with a big discount (look bottom of page) here :
https://virtualdj.com/buy/
ah yes ;)
Thats the way..
