Was thinking of buying virtual DJ along with some TCV ... Is anyone using a Xone62 ...If so whats the best way to rig her up ..... (delta 44 soundcard).
Thanks for your time.
geposted Thu 23 Jun 05 @ 5:38 pm
...Okay I`m a bit new 2 this sort of set up ... and I`m basically looking for the best way to set up with
TCV ... I wanna use my turntables with the Xone 62 ... do I need 2 soundcards ?... I don`t wanna use PC speakers ... but the ones hooked up 2 my mixer ...
If understand that your a better man than me ....
Cheers.
Cheers.
geposted Thu 23 Jun 05 @ 8:31 pm
Forget the Delat 44 .... I`ve managed to source a maya 44 USb ..
....still need help to setup though...
Thanks
Thanks
geposted Thu 23 Jun 05 @ 9:40 pm
https://virtualdj.com/support/VirtualDJ%203%20-%20Advanced%20ASIO%20configuration.pdf
Copy the entire link above. This is where you need to start.
cstoll
cstoll
geposted Thu 23 Jun 05 @ 11:11 pm
Yeah thanks .... so the turntables directly into the maya ... and then out into the required channels in the mixer .... why is the other soundcard required ....
geposted Thu 23 Jun 05 @ 11:18 pm
You only need the maya44 soundcard, no other soundcard is required.
geposted Fri 24 Jun 05 @ 12:28 am
... fair enough .... it`s that easy ... what about the mixer with the software. Do you have control with the mixer over the software ...
Sorry to burst all your balls ...
geposted Fri 24 Jun 05 @ 12:39 am
Norway is right from a playing standpoint but if you want to record your mix you'll need another card. The record or booth out on your mixer will then plug into that card for recording.
geposted Tue 28 Jun 05 @ 4:12 pm
Thanks 4 the advice ....
geposted Tue 28 Jun 05 @ 5:32 pm
