Heres my problem I had a Pc made for block parties ones thats waterproof and the best part it's sunlight readable at almost any angle it's an industrial LCD but with all good thing comes something bad it can only support 800x600 resolution so if anyone can help in either making or to modify a current skin to work on 3.0 i would greatly appreciate it Thank you all
geposted Fri 24 Jun 05 @ 12:31 am
There are some existing skins that work for 800x600. Look on the skin download page.
The maybe some problems with old skins due to their out of date.
If you want me, or someone else to modify a current skin to work on 3.0, then tell us what skin you prefer.
I'm getting actually quite quick on editing existing skins to add new features.
geposted Fri 24 Jun 05 @ 1:08 am
Try the DENON 1800 F BLACK 4 and you'll be surprised!!
FRUiT94
FRUiT94
geposted Fri 24 Jun 05 @ 3:11 am
Thank you lej78480 and Fruit My Prefered Skin is the VDJ advanced skin but i doubt it can work with the video preview window on a 800x600 resolution if it can be done it would be great thanks for any help.
geposted Tue 28 Jun 05 @ 1:34 am
well i tried to make my own 800x600 skin but i didnt do such a good job so ima need some help
geposted Thu 07 Jul 05 @ 5:26 pm
