ok i know some1 told u can play 2 or songs at the same time but i was how can i mix more then 2 songs at the same time(for example ill play one song on deck A and B how do u get to play the 3rd one). is there a effect kind like Echout but it stops the song after i hit it cause i notice that ill stop the song but the effect will stop to. i want to be able to stop the song the echout 2 continue in effect. any suggestion?? overloop doesn't do what im looking cause it doesn't echo the song.
Thanks
Dj HaPpEe
Thanks
Dj HaPpEe
geposted Fri 24 Jun 05 @ 4:40 am
try this,
you can record your loop into a sample and then loop it during the end so you can stop your song but the sample plays on...
Adi
Adi
geposted Fri 24 Jun 05 @ 6:34 am
Right; the sampler is very efficient. Have a try with it.
geposted Sat 25 Jun 05 @ 10:53 am
