Παιδες την βοήθεια σας έχω τον εν λόγω controller και θέλω να μαπαρω κάποια κουμπιά λίγο διαφορετικά
Για αρχή πως μπορώ να κάνω ένα κουμπί να έχει ιδιότητες SHIFT
ευχαριστω!!!
ευχαριστω!!!
geposted Mon 25 Oct 10 @ 3:50 am
Poia version tou virtualdj exeis ?
Den eimai sigouros... pws h version tou virtualdj pou erxete me ton controller sou epitrepei na kaneis kati tetoio.
geposted Mon 25 Oct 10 @ 5:13 pm
Auta pou tha grpasw vevaia isxyoun gia olous tous controllers eite exoun koumpi SHIFT eite den exoun.
Katarxin dialegeis poio koumpi tha kaneis SHIFT, giati auto me auto to koumpi den tha mporei na kanei alles douleies, i toulaxiston tha einai ligo epikindyno na kanei ki alles..lol
Gia to koumpi auto dineis action...
An twra theleis ena allo koumpi na symperiferetai analoga me to an exeis patimeno to SHIFT i oxi, dineis action..
To koumpi loipon pou tha antistoixisete tha ektelei tin action1 otan exete to SHIFT patimeno alloiws tha ektelei tin action2
An px theleis me to SHIFT patimeno na kanei REVERSE PLAY kai xvris na einai patimeno na kanei PLAY ..dineis action...
set var 'shift' 1 while_pressed
var 'shift' ? action1 : action2
var 'shift' ? deck 1 reverse : deck 1 play_pause
geposted Mon 25 Oct 10 @ 6:07 pm
milame panta gia thn 7
eyxaristw 8a prospa8isw kai 8a epanel8w
geposted Wed 27 Oct 10 @ 5:15 am
boys epanerxomai!
1) h entolh moy doylepsai mono etsi
<map value="AUTOMIX" action="set $shift while_pressed" />
<map value="PITCH" action="var $shift ? master_volume : param_multiply 1% & pitch" />
diladi 8elei kai to "$"
2) sto parapano paradigma pws mporw na diaxorisw otan einai se litoyrgia "shift" to aristero apo to deksi pitch gia na mporo na elenxw to master volume me to ena kai to cue volume?
exaristw poly kai pali!!!
geposted Fri 26 Nov 10 @ 2:14 am
dokimase
var $shift ? device_side_left ? master_volume : headphone_vol : pitch
Thewrw omws oti na mappareis ta pitch gia autes tis leitourgiies tha sou kanei ti zoi dyskoli, giati afou rythmiseis to headphones volume, otan epanafereis to shift, to pitch sou tha deixnei alla nt allwn.
geposted Fri 26 Nov 10 @ 7:31 am
djdad wrote :
dokimase
den doylepsai
oso gia to allo poy les gia to pitch sthn dj controlmp3 e2 ta phitch tis einai peristrofika me atermona opote den yparxei kanena problima
(htan kai enas apo toys logoys poy thn dialeksa!)
geposted Fri 26 Nov 10 @ 8:12 am
Katarxin egrapsa lathos to headphone.. to swsto einai
var $shift ? device_side_left ? master_volume : headphone_volume : pitch
Epeidi den eimai mprosta se konsola prepei na mou peis pws symperiferetai, to oti den douleuei den mou leei tipota. An prokeitai gai atermona prpei na valeis kai param 1%
geposted Fri 26 Nov 10 @ 10:08 am
loipon etsi doylebei mono to headphone vol kai me ta dyo pitch eno to master volume den "akoyei"
var $shift ? device_side_left ? master_volume : headphone_volume : param_multiply 1% & pitch
eyxaristw!!!
geposted Fri 26 Nov 10 @ 1:30 pm
To koumpi pou allazei to shift einai logika 2, ena se kathe meria etsi?
An patiseis to aristero shift douleuei opws an patiseis to deksi. ?
To $ sto shift to kanei global, dokimase kai xwris to $
geposted Fri 26 Nov 10 @ 1:37 pm
opaaa..twra to eida...
to swsto einai device_side left oxi device_side_left
geposted Fri 26 Nov 10 @ 1:40 pm
super ayto htan
thx!!!!!
geposted Fri 26 Nov 10 @ 2:07 pm
ok.. apo oti eida to prwto post, mas pire ena mina, alla to kataferes...xexexe
geposted Fri 26 Nov 10 @ 2:10 pm
lol kai emena epese to mati sthn hmerominia kai skeytika oti exei perasei enas minas kai den hxa kanei tipota!!
oxi!! shmera to ksana epiasa to 8ema
blepeis to virtualdj exei pola metopa!!!
geposted Fri 26 Nov 10 @ 2:45 pm
gia na mhn anigw kenoyrgio 8ema:
8elw thn boi8ia sas se maparisma enos koympioy etsi oste na energopoiei kai na apenergopoiei to crossefader kikika diladh pantontas energopoihte ksana pantontas apenergopoihte
kai kati akoma ton kodika gia na exoyme tin endiji sto skin tis ri8mihs toy crossfader.
geposted Sat 29 Jan 11 @ 5:56 am
Τώρα πρόσεξα το νήμα...
Καταρχήν η εντολή
Set var "$shift" while_pressed
ενεργοποιεί την παράμετρο "shift" για όλα τα deck. Αν θες διαφορετικό κουμπί shift για κάθε deck τότε το σωστό είναι
set var "shift" while_pressed και φυσικά το "shift" δουλεύει μόνο στο deck που το πατάς.
Τώρα για το crossfader:
cycle var "$crossfader" 1 & var_equal "$crossfader" 1 ? crossfader_curve "disabled" : crossfader_curve "smooth"
Για το skin ισχύει περίπου το ίδιο. Αυτό που χρειάζεται να ελέγχεις είναι το crossfader_curve το οποίο μπορεί να πάρει τιμές "smooth", "full", "scratch", "cut", "disabled" ή απο 0% (Χ) μέχρι 100% (ανάποδο U)
Καταρχήν η εντολή
geposted Sat 29 Jan 11 @ 7:55 am
giorgo moy bgazei syntax error :(
geposted Sun 30 Jan 11 @ 4:14 am
cycle "$cross" 1 & var_equal "$cross" 1 ? crossfader_curve "disabled" : crossfader_curve "smooth"
geposted Sun 30 Jan 11 @ 6:32 am
giorgo oyte kai ayto doylepsai to mono poy mporesa na doylepsw einai ayto
var $shift ? crossfader_curve 'disabled' : var $shift2 ? crossfader_curve 'scratch' : browser_scroll -1 & deck 1 wheel_mode 'browser' while_pressed & deck 2 wheel_mode 'browser' while_pressed
dyladi exw dyo koympia shift kai me enan syndiasmo shift+buton apeneropeiw to cross kai me ton allo syndiasmo shift2+buton energopeio to cross se mode scratch.
bebaia 8a protimoysa na to ekana mono me ena syndiasmo koympiwn kai na ebaza kai alla mode toy cross (cycle) gia paradigma opos ginete parakatw me to pitch range
holding ? pitch_range '8,12,33,100' : master_tempo"
an exeis esy h' kapoios allos kapoia allh idea...
twra oso afora tin endiksi toy crossfader_curve sto skin prospa8ontas me textzone den mporesa na petixw kati oso kai a prospa8isa
exei kapoios kamia protash gia boh8eia
geposted Mon 31 Jan 11 @ 5:24 am
Erwtisi.. i konsola sou exei koumpi SHIFT apo tin mana tou? Ston native mapper den vlepw kati me shift. Poio koumpi exeis valei na kanei SHIFT?
Poia entoli exeis dwsei gia to SHIFT? Ennow kanei cycle, oso to patas, i to exeis while_pressed ? To koumpi auto pou exeis orisei SHIFT, exei LED? Tha mporouses na kaneis to LED analoga me tin timi tou SHIFT na einai einai off, on, blink.
geposted Mon 31 Jan 11 @ 5:40 am
