Buying virtual dj when my laptop arrives. Do i need an external sound card for cueing or is it possible to do it on one. Please recommend some external soundcards usb if I need one. thank you
geposted Fri 24 Jun 05 @ 9:06 pm
I would say the majority of VDJ users, use Maya 44. It is a external USB sound card
geposted Fri 24 Jun 05 @ 11:08 pm
maya44 is recommended to use with TCVs or TCCDs. You don't need the maya44 to use VDJ at it's best. You can get other soundcard. you will need at least 2 outputs on the soundcard.
Maybe your internal soundcard from your labtop is a 5.1 system. Then you will be able to use that soundcard with VirtualDJ.
geposted Sat 25 Jun 05 @ 12:29 am
If you don't plan on using TCVs or TCCDs in the future then I suggest the ESI Gigaport. It is the same USB sound card as the Maya44, just all outputs. Very easy to setup and use.
cstoll
cstoll
geposted Sat 25 Jun 05 @ 9:01 am
If you dont plan to use Timecode (vinyl or cd's) the hercules dj console is a GREAT soundcard, and includes an ok midi controll unit for VDJ as well...
geposted Sun 26 Jun 05 @ 5:47 pm
i didnt know that the hercules was an external sound card as well thnx norway
geposted Mon 27 Jun 05 @ 9:53 am
Yes it is I answered you on the other topic. ;)
geposted Mon 27 Jun 05 @ 9:55 am
I just purchased my VDJ and been tinkering w/it. My question is I oredered the MAYA 44 USB soundcard. Did I order the correct soundcard? (hasn't came in yet) My setup will be mixing tracks on home pc w/vdj and wanting to cue up music via headphones. T
Thanks
Thanks
geposted Tue 19 Jul 05 @ 11:07 pm
maya is a great soundcard that works well with VDJ :)
geposted Wed 20 Jul 05 @ 12:32 am
