I come from using PCDJ VJ 5.1 and 5.2 and Im trying to migrate to VDJ 6.2 and now 7.0. I got used to the clean skin VJ provided and the separate icons that VJ uses for Music and Video as well as the color coding for music or karaoke tracks. My laptop screen is 1280x800 and using the 1024x800 VJ skin is very ackward. I've tried to get used to the VDJ skin but I cant easily differentiate the small file type icons. I am unable to differentiate the V from the K.
Does anyone has a 1280x800 VJ skin?
I dont mind at all if the audio crossfader is missing from the skin. I never use the internal mixer.
geposted Thu 28 Oct 10 @ 2:41 pm
There are a ton of skins here ( https://virtualdj.com/addons/skins.html?category=video ) you just have to sift through them to find the size that fits you.
geposted Thu 28 Oct 10 @ 3:58 pm
about the icons in the skin... you can change them using icons from other skins. Here is a picture from the icons i use in my skins (TCmania, Rusty, Plasma, VMS4, etc)
The list explains the icons as shown (order)
Karaoke file
Already Played
Unknown (unscanned)
Audio
Video
DifBpm
geposted Thu 28 Oct 10 @ 4:59 pm
Jam Master Rob, I know there are a lot of skins available for download but there is none that replicates the VJ Skin in 1280 x 800.
DjDad, would I have to modify the skin bmp file to change the icons?
geposted Wed 03 Nov 10 @ 8:28 pm
Yes, you have to copy the icons part of the bmp file of one of my skins above and paste it to the skin you use. Then you will probably have to adjust the xml file a little bit with the x,y of the customicons line.
geposted Wed 03 Nov 10 @ 8:43 pm
