Hello,
I use the samplebank as a drumcomputer but sometimes the beat doesn't match with the BPM. And yes....the BEAT MATCH is on.
geposted Sun 31 Oct 10 @ 6:55 am
try to tap out the the beats manually. The computer might have not set it properly.
geposted Tue 02 Nov 10 @ 12:08 am
By taping you might not be very accurate. Better to use the cbg adjust actions. Usually the bpm is correct, but the grid are in the wrong position and probably this is the reason you dont get the beatmatch with your samples.
geposted Tue 02 Nov 10 @ 8:06 am
