Hey guys, i have a Numark DXM01 mixer, its abasic mixer with the basic requirements. The output is available as 1.Two RCA outputs labelled-MAIN
2.Two RCA outputs labelled-RECORD
I do not have an amp at home , but can anyone please tell me how do i connect the mixer to the amp? as i will need to know how to connect the mixer at a club or during parties...
a detailed explanation would be great! or if anyone can provide a link.
As an example, take a Numark amplifier to explain the conections(just as an example)
Thanks a lot.
Thanks a lot.
geposted Sat 25 Jun 05 @ 4:08 pm
just put the output of the mixer to the input of the amp, nothing difficult there
you can use the record output to rec. you're mixes to an md or something
geposted Sat 25 Jun 05 @ 6:02 pm
DUh...i know that man...i was talking about the less obvious stuff..
i need more detail...my mixer has rca outputs but the amp has 1/4'' inputs..how do i connect it?
thanks anyways..
thanks anyways..
geposted Sat 25 Jun 05 @ 9:40 pm
Couple choices:
1. RCA to 1/4" Cable
RCA (mixer) ---> 1/4" Tip-Sleeve (amp)
2. RCA to RCA Cable to RCA to 1/4" Adapters on one end
RCA (mixer) ---> RCA w/ 1/4" Adapters (amp)
Here is a link to radioShack with the RCA to 1/4" Adapter
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F011%5F003%5F001%5F001&product%5Fid=274%2D884
cstoll
cstoll
geposted Sat 25 Jun 05 @ 11:06 pm
Great! thanks a bunch cstoll! Now i clearly understand...
thanks!
thanks!
geposted Sun 26 Jun 05 @ 6:17 am
