I'm running VDJ demo and I believe that the Timecode CD won't work on the demo version.
Before I get the full version I would like to know if my cofiguration will work.
The only sound card I have is the one in my Laptop, all it has is a mic in and headphone out. Can I still use a time coded CD with this configuration or will I have to get another sound card.
Also how accurate is the pitch shift, when I increase the speed on my CD decks by .1% will VDJ increase by the same amount as the programe itself only goes up by .2%
STEVE
STEVE
geposted Sat 25 Jun 05 @ 5:49 pm
About soundcard: your current soundcard will not be sufficient to connect your cd player. You will need a more complex sound interface to connect your cd player. Try the Maya44 usb sound interface. run a google searh on it and you will find more info..
Iam not able to help you about the pitch, as i'm not a user of a timecode cd...
hope this info was of use...hoping to see you as a full registered user!
Adi
Adi
geposted Sat 25 Jun 05 @ 9:51 pm
In fact you can't use the mic input as it's only mono and you need a stereo input (line in)
geposted Sun 26 Jun 05 @ 3:42 pm
