Beatmatch engages by itself on certain songs when I mix (ALT+Space) This didn't happen until I upgraded to 3.0; how can I stop this. It happens always on the same songs. I see you refer to SYNC button by that's not here now.
geposted Sat 25 Jun 05 @ 8:22 pm
Yes, it is supposed to happen, since pressing ALt+Space means you are telling it to AUTO mix...pressing SHift+Space does the sync-ing...which skin do you use?
geposted Sat 25 Jun 05 @ 9:48 pm
Have a look at your shortcuts. Many actions can be applied to the same key.
geposted Sun 26 Jun 05 @ 2:15 pm
I am using the stock skin. How do I just fade from one side to the other using a key stroke without changing any tempos?
geposted Mon 27 Jun 05 @ 8:03 pm
page up and page down moves the crossfader :)
geposted Mon 27 Jun 05 @ 10:07 pm
