hi everybody i have a problem with my sound...
i use a hercules
Virtual dj 3.0
A suround system one subwoofer and 4 smaller hi med speakers...
headphones
a 5.1 internal soundcard
my problem is that
i want to plug in the speakers to the computers internal soundcard
i want to plug in my headphones into my hdjc
iv´e plugged it this way but.
the thing is now that only 2 speakers and the subwoofer ofcourse. the headphones is dead...
how should i plugg it and how sholud my sttings be like...
i´m all cunfused now so it might be hard to understand what i want but ask if there is anything that u don´t understand.
Thanks in regards...
i use a hercules
Virtual dj 3.0
headphones
my problem is that
geposted Sat 25 Jun 05 @ 11:12 pm
Hi Hannep,
I understand what you want to do, and here are the instructions:
open VDJ, select confiq, select soundcard, then select advanced configuration.
Left deck = internal soundcard (left and right) front (1) channel.
Right deck = internal soundcard (left and right) back (2) channel
Headphone = Hercules DJ Console.
This should work just fine ;). Hope i've been of help to you.
Bagpuss
Bagpuss
geposted Sun 26 Jun 05 @ 6:30 am
or select the two soundcard option (the first picture with two soundcards I believe) and asign the first one to your soundblaster, and the second to your dj console. connect the speakers to your soundblaster and your headphone to the dj console. worked for me...
geposted Mon 27 Jun 05 @ 4:10 am
