Forum: Old versions
Topic: i cant update
when i try to enter my serial or my email it says its invalid. i paid the same 118+usd everyone else did why is my program not updating! someone anyone can you help me out?
geposted Sun 26 Jun 05 @ 3:50 am
Make sure you're putting the correct serial in. It will defenitely work when the correct serial's put in. Also make sure that the computer you're using for VDJ is online when you install VDJ.
Failing that, contacting eservice will help...
https://virtualdj.com/support/e-service/
Good luck...
P
and welcome in the future.
